reubadoob
Oct 06, 2022Aspirant
AXE11000 Waiting for Internet Comcast Business
After suffering a power outage due to Hurricane Ian my AXE11000 is not connecting to the internet despite being assigned an IP address from the Comcast Business router I have it plugged into. ...
Oct 06, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Did you use Dynamic or Static AP configuration on the RBR? Static is recommended.
- reubadoobOct 06, 2022Aspirant
I've done all of the steps you have suggested. None of which have resolved the issue.
ISP Modem Hardware
Model: CGA4131COM
Vendor: Technicolor
Hardware Revision: 2.3
Serial Number: 190968231155600091Using CAT6 throughout.
