reubadoob
Oct 06, 2022Aspirant
AXE11000 Waiting for Internet Comcast Business
After suffering a power outage due to Hurricane Ian my AXE11000 is not connecting to the internet despite being assigned an IP address from the Comcast Business router I have it plugged into. ...
Oct 06, 2022Guru - Experienced User
What happens if you configure the RBR for router mode, put the IP address that the RBR gets from the Modem into the modems DMZ.
Are the RBS wired or wireless connected to the RBR?
reubadoob
In router mode the RBR assigns all the connected devices IP addresses as expected, 192.168.x.x.
Comcast router/model assigns the RBR the correct IP reservation I have set up (10.1.10.153) as expected.
I added it to the DMZ within the Comcast router/modem as suggested.
Still no internet connection via the RBR.
The RBS are wired via CAT6
- FURRYe38Oct 06, 2022Guru - Experienced User
Sounds like something on the modem isn't getting fully thru to the RBR in ether mode.
i'd check for any blocking features on the modem. DMZ should work to by pass any and all modem features but possible something is still not working right.
There a friend, neighbor or family member that you can take the RBR to to see if it works at a different location with a different modem to see IF problem follows?
RBS are connected to the back of the RBR?
