gillshreyas
Nov 21, 2023Follower
AXE11000 WiFi Mesh: Connectivity Problems?
I recently purchased the NETGEAR AXE11000 WiFi Mesh System, 've encountered a couple of issues that I hope the community can shed some light on. My Samsung Galaxy S20, connected to the AXE11000, face...
Nov 22, 2023Guru - Experienced User
What model Orbi system do you have RBK9##?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
gillshreyas wrote:
I recently purchased the NETGEAR AXE11000 WiFi Mesh System, 've encountered a couple of issues that I hope the community can shed some light on. My Samsung Galaxy S20, connected to the AXE11000, faces frequent connectivity drops within close range. How did you address similar issues with this device, and have you found a solution?" While the AXE11000 is touted for its high-speed capabilities, I've observed fluctuations in performance. Sometimes the speeds are impressive, but on other occasions, there's a noticeable drop in speed. Are there any optimization tips or firmware updates that might address these performance variations?
