JaxSully's avatar
Feb 09, 2022
AXE11000/RBRE963 RBS Static IP
All,   Just purchased and installed the AEX11000 and converted from Nighthawk X10 with MOCA backhaul to Netgear AP's. First I love it and will try to put as much into the community as I take out.  ...
  • FURRYe38's avatar
    Feb 09, 2022
    RBS don't support setting of a static IP address on the RBS themselves. If you want a set IP address to be assigned to the RBS, then you'll need to input a IP address reservation ON the RBR for each RBS. Something that is recommended. I do this as well.
