willybobby
Aug 19, 2023Aspirant
Backhaul Ethernet - Orbi 960 + Switch Ubiquiti Enterprise XG-24
Hi, I have the following configuration : NetGear Orbi 960 Kit including 2 satellites (all on the latest firmware) Switch Ubiquiti Enterprise XG-24 (latest firmware) A house with wired CAT7 cable...
Aug 19, 2023Guru - Experienced User
IF the RBS work directly connected to the back of the RBR with out the switch, then this is a switch problem. Try the suggestions to disable IGMP and Green Ethernet features on the switch.
Try a different switch as well. XS505M and GS110MX work great with the 9 series.
Be sure to first wirelessly sync the RBS to the RBR, then ethernet connect them.
