todd2468
Dec 27, 2020Follower
Backhaul status on router disconnected
Hi. My backhaul status on the router Orbi AX6000 (RBR850) shows up as disconnected. I am also seeing wireless issues in this room. Disconnected status makes sense on a satellite, but not on the route...
Dec 27, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
