Ar0s
Apr 24, 2021Follower
Backup Internet connection with a LTE router - possible?
I installed a Orbi AX4200 system (1 router and 1 satellite) connected to the ISP router. I am wondering if I can connect a LTE router and configure the Orbi system to use it as backup connection prov...
Apr 24, 2021Guru - Experienced User
Orbi systems do not support WAN side failover. You'll need something infront of the Orbi system as mentioned by ekhalil that supports failover features.
Ar0s wrote:I installed a Orbi AX4200 system (1 router and 1 satellite) connected to the ISP router. I am wondering if I can connect a LTE router and configure the Orbi system to use it as backup connection provider in case the main cable connection fails.
Any hint is welcome
