UrbanL
Apr 04, 2020Guide
Bad connection to Orbi RBS850 satellite
Hello I bought an Orbit RBK853 (with RBR850 and RBS850) before Christmas 2019. I'm about to throw the device out and buy another product, because I have several problems so far and still no solution...
- Apr 16, 2020
Any older CAT5 cabling, I would upgrade for sure. CAT6 is mimimum now days.
Glad the system is working now. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
UrbanL
Apr 05, 2020Guide
Thanks for your fast reply - I try to anwser them
1. What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
UL: the Manufaktur is arcadyan model vrv9519 labled by my telco provider swisscom
2. Is the Orbi system operating in Router or AP mode?
UL: no it is router mode - and I connected it to my router from my telefon company -> might this be a / the problem?
3. What is the size of your home? Sq Ft?
UL: about 3000 SqFt (=280sqm - but I'm not using it for all sofar).
4. What is the distance between the router and satellite(s)?
UL: 30 ft = 10meter
5. What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on
UL: not sure - just found in Orbi-Mob-App 8 and 48
6. 2.4Ghz and any unused channel on 5Ghz.
UL: ??
7. Any Wifi Neighbors near by? If so, how many?
UL: yes but actually quit far away. I usually see about 4-6 other wifis
8. IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes.
UL: IPv6 is currently disabled - should I turn it on?
best regards
Urban
Apr 05, 2020Guru - Experienced User
It maybe possible that this model has a built in router and wifi already...if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try setting manual channel to 1, 6, 11 or 13. Use a web browser to log into the RBRs web page to change channels, you can't change channels using the Orbi app.
- UrbanLApr 16, 2020Guide
thank you for the answer. I have now had the time to reinstall everything again. So far it looks like I have no more connection problems. But every now and then the network is still very weak 3Mbps instead of 500Mbps. I will now renew all my old Ethernt cables to Kat7 and hope to have a really good network :-) Thanks again!
- FURRYe38Apr 16, 2020Guru - Experienced User
Enjoy. :smileywink:
