MB_Love
Feb 24, 2021Apprentice
Bad Ethernet cord? Advice please!!
Slow Orbi AX- could it be Ethernet cord? Here is the deal. Have has Orbi (RBK853) since June - ran flawless. ISP had a wide outage last week. Came back fine. Now 2 days in a row our internet has sl...
MB_Love
Modem is Arris TG862G
I have RBR850 with 2 satellites - latest firmware v3.2.16.22
Feb 24, 2021Guru - Experienced User
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- MB_LoveFeb 24, 2021ApprenticeI Must have given you wrong model # - because it is đź’Ż only a modem.
Yes, I just checked and it is actually the arris TM1602- sorry was away from home and looked up off spectrum site (similar looking modems). Not a router (neither is the other model)- FURRYe38Feb 24, 2021Guru - Experienced User
Ok.
Well if the system was working ok before this ISP outage. I would represume if it's not working now, then the ISP services need to check into this.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853- MB_LoveFeb 24, 2021ApprenticeThey think it’s port in the modem, sending a new modem.
