Yots
Sep 01, 2022Aspirant
Band Bew Orbi router/Satellite (AX210) will not connect to phone
I have this issue where my brand new Orbi router won't connect to ANY mobile device. Although 2 computers in the house using wifi work PERFECTLY.
After some trouble shooting, i was able to make the router connect to a MacBook(fully fontional) and the phones(partly functional) BUT only a few of them. For some reason, only a few application on the phones are functional, while other apps are not.
I am not sure how to proceed.
This has never happened before.
Also, the Orbi router is connected to my original ISP AC router via internet cable.
Last thing is that after configuring the router, the orbi app prompted that "unable to connect to your orbi device. You might be connected to the guest network" and now i cant access the router either. Keep in mind that i am NOT connected to the guest network as it shows up in the network list as "Netgear-Guest".
Any help is welcome!
Thank you!!
For a start it helps to think of things the right way round. Your router doesn't connect to mobile devices. They connect to the router.
Also, the Orbi router is connected to my original ISP AC router via internet cable.If you are running with two routers on your network, that could explain why the devices cannot connect to the Orbi. You have two routers trying to act as traffic managers. A recipe for chaos.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. There may be ways to get the modem/router to cooperate. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
A lot of people use an Orbi system in AP mode, especially if they have a decent router in front of it. Only you know which of your two routers provides the best features for your needs.Finally, you have an Orbi system. While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Support | NETGEAR
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - FURRYe38Guru - Experienced User
What model Orbi do you have?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
After some trouble shooting, i was able to make the router connect to a MacBook(fully fontional) and the phones(partly functional) BUT only a few of them. For some reason, only a few application on the phones are functional, while other apps are not.I am not sure how to proceed.
Also, the Orbi router is connected to my original ISP AC router via internet cable.Last thing is that after configuring the router, the orbi app prompted that "unable to connect to your orbi device. You might be connected to the guest network" and now i cant access the router either. Keep in mind that i am NOT connected to the guest network as it shows up in the network list as "Netgear-Guest".
Thank you!!- YotsAspirant
Everything is working fine now.
after resetting the router, it auto configured and now is working perfectly.
thank for the help!- FURRYe38Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
