tigerisak
Nov 26, 2023Guide
Bang & Olufsen multi room and Netgear Orbi RBR850
I have issues getting Bang & Olufsen multi room to work with my wireless products connected to RBR850 and its connected satellite. Bang & Olufsen is stating that this is a known issue and that Netgear...
Nov 26, 2023Guru - Experienced User
This is the community forum, doubtful you'll get info from engineering on here.
What actual issue are you having?
What modem/gateway is the router connected to?
What B&O devices do you have?
HOw are they connected? Via wireless? Wired? If wired, to the router or satellites?
Reason I ask is sonos had/has an issue with satellites. If they're hardwired in, they need to be to the router and not satellites.
tigerisak
Nov 26, 2023Guide
Issue is that Bang & Olufsen multiroom is not working. And this is a known issue and Bang & Olufsen have escalated this to Netgear.
I live in an apartment complex with a Cat7 "box" for internet. So not sure of the gateway in the basement.
Beovision Eclipse (hardwired), Beosound Shape (Hardwired), Beosound Emerge (wifi), Beolab8 (wifi/WISA). Issue is only with the wifi units. All connected to the router.
Please advise.
- FURRYe38Nov 26, 2023Guru - Experienced User
What do you mean by the B&O isn't working? Can you explain in more detail of what that means?
What FW version is loaded on the Orbi system?
- tigerisakNov 26, 2023Guide
The Bang & Olufsen multi-room doesn't work when it comes to "extend" the sound to other units. Such as playing music on the Beolab8 and then extending it to the Beosound Emerge.
- plemansNov 27, 2023Guru - Experienced User
Whenever I hear "it comes from a cable in the wall" and is supplied by the apartment, I know things can get challenging.
If its supplied by the apartment, they could have their own NAT/firewall that's causing issues. Some of the sound (like sonos and B&O) need that connection back to their own server and the apartment firewalls can create issues with it.
Does the orbi and B&O work fine if its just the router running (satellites shut off)?
if not, then I'd be more curious about the apartments ISP implementation.- tigerisakNov 27, 2023GuideSame issue if I turn off the satellite and only running with router.
Something to try that might cause you to have to reset the router is put it in access point mode.
Access point mode disables all its routing functions and leaves whatever is on the other end of your apartments "connection" to manage the routing functions. See if it works.
If it doesn't and you can't access the router, you'd need to factory reset to get back in.If it does it either means a double nat is causing it (the apartments routing and the orbi's routing) or something in the netgear is blocking it.
