tigerisak
Nov 26, 2023Guide
Bang & Olufsen multi room and Netgear Orbi RBR850
I have issues getting Bang & Olufsen multi room to work with my wireless products connected to RBR850 and its connected satellite. Bang & Olufsen is stating that this is a known issue and that Netgear...
tigerisak
Nov 26, 2023Guide
What actual issue are you having?
Issue is that Bang & Olufsen multiroom is not working. And this is a known issue and Bang & Olufsen have escalated this to Netgear.
What modem/gateway is the router connected to?
I live in an apartment complex with a Cat7 "box" for internet. So not sure of the gateway in the basement.
What B&O devices do you have?
Beovision Eclipse (hardwired), Beosound Shape (Hardwired), Beosound Emerge (wifi), Beolab8 (wifi/WISA). Issue is only with the wifi units. All connected to the router.
Please advise.
Nov 26, 2023Guru - Experienced User
What do you mean by the B&O isn't working? Can you explain in more detail of what that means?
What FW version is loaded on the Orbi system?
- tigerisakNov 26, 2023Guide
The Bang & Olufsen multi-room doesn't work when it comes to "extend" the sound to other units. Such as playing music on the Beolab8 and then extending it to the Beosound Emerge.
