tigerisak
Nov 26, 2023Guide
Bang & Olufsen multi room and Netgear Orbi RBR850
I have issues getting Bang & Olufsen multi room to work with my wireless products connected to RBR850 and its connected satellite. Bang & Olufsen is stating that this is a known issue and that Netgear...
Nov 26, 2023Guru - Experienced User
What do you mean by the B&O isn't working? Can you explain in more detail of what that means?
What FW version is loaded on the Orbi system?
tigerisak
Nov 26, 2023Guide
The Bang & Olufsen multi-room doesn't work when it comes to "extend" the sound to other units. Such as playing music on the Beolab8 and then extending it to the Beosound Emerge.
