tigerisak
Nov 26, 2023Guide
Bang & Olufsen multi room and Netgear Orbi RBR850
I have issues getting Bang & Olufsen multi room to work with my wireless products connected to RBR850 and its connected satellite. Bang & Olufsen is stating that this is a known issue and that Netgear...
tigerisak
Nov 26, 2023Guide
What actual issue are you having?
Issue is that Bang & Olufsen multiroom is not working. And this is a known issue and Bang & Olufsen have escalated this to Netgear.
What modem/gateway is the router connected to?
I live in an apartment complex with a Cat7 "box" for internet. So not sure of the gateway in the basement.
What B&O devices do you have?
Beovision Eclipse (hardwired), Beosound Shape (Hardwired), Beosound Emerge (wifi), Beolab8 (wifi/WISA). Issue is only with the wifi units. All connected to the router.
Please advise.
Nov 27, 2023Guru - Experienced User
Whenever I hear "it comes from a cable in the wall" and is supplied by the apartment, I know things can get challenging.
If its supplied by the apartment, they could have their own NAT/firewall that's causing issues. Some of the sound (like sonos and B&O) need that connection back to their own server and the apartment firewalls can create issues with it.
Does the orbi and B&O work fine if its just the router running (satellites shut off)?
if not, then I'd be more curious about the apartments ISP implementation.
- tigerisakNov 27, 2023GuideSame issue if I turn off the satellite and only running with router.
- plemansNov 27, 2023Guru - Experienced User
Something to try that might cause you to have to reset the router is put it in access point mode.
Access point mode disables all its routing functions and leaves whatever is on the other end of your apartments "connection" to manage the routing functions. See if it works.
If it doesn't and you can't access the router, you'd need to factory reset to get back in.If it does it either means a double nat is causing it (the apartments routing and the orbi's routing) or something in the netgear is blocking it.
I have tried that. Doesn't work.
As all wired devices work fine with Multiroom I suspect it to be something with the WIFI.
