FosterPhotos
Jan 18, 2022Follower
Best mesh models to buy?
I have Xfinity cable modem (Arris TG4482A) and am paying for 600 mbps download speed. Our home is about 3000 sq ft. We have about 15 devices connected to wifi. We want 2 desktop computers that are not next to the cable modem to have maximum download speed either wireless or wired. Would a netgear Orbi mesh system be the best solution? What model? Thanks for your recommendations.
1 Reply
You might start here:
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡FYI: Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
