SanJuanJan's avatar
SanJuanJan
Follower
Aug 10, 2020
Best Modem for Orbi AX6000 RBK853
I am planning to buy an Orbi RBK853 system; my home is approx. 5000 sq. feet. I currently have Cox Gigablast. I need to get a new modem (as I am renting my current one).  What is the best modem to buy, especially if Cox upgrades service to more than 1 gig.   I'm thinking a Netgear might be best for compatibility with Orbi, but maybe that is not an issue--any thoughts? Also, is there any point in getting a modem with a router, or would it conflict with the Orbi router?  Thank you!
  • NGs CM1000, CM1100 or CM1200 work well with Orbi AX. Check with your ISP to see what they officially support before buying.
1 Reply
  • FURRYe38's avatar
