Jonnyappleseed
Oct 31, 2022Follower
Best modem?
I have a RBR750 with one satellite and I want to ditch my Comcast modem and get something from Netgear....appreciate the suggestions.
Oct 31, 2022Guru - Experienced User
Check with the ISP to see what is supported on there network.
NGs CM series of modems are pretty good.
- plemansOct 31, 2022Guru - Experienced User
The CM2000 is currently the top of the line for xfinity if you're looking modem only
If you're needing modem/voice, then the cm2050v is the voice version.
If you don't need 2.5gig ports, the cm1000, cm1100, cm1200 are all rated for gigabit speed and are docsis 3.1 devices
