gjrandazz
Jun 21, 2021Aspirant
Best NG router to use with RBK753S
I would like to use this Orbi system with another Netgear or 3rd party router. First off, is this possible and if so, which other NG preferably, would be a good one to compliment this 753S mesh system...
gjrandazz
Thanks for the reply
Home is about 1200 feet
3.2.18.1 is firmware for both RBR750 and 2 RBS750
I use an Arris 8200 modem
My ISP is 1gig coaxial
I see no setting for Armor
Shield Pro is wired straight from router only a couple of feet away.
My speeds are fine, both when wired and wireless. However, when I try to connect to my VS on the Shield, I get very high latency and bad results for bufferbloat
Jun 21, 2021Guru - Experienced User
What is the distance between the router and satellite(s)?
What is this VS?
Can you turn OFF the RBS and try this one device with the RBR only?
Do you see same latency if you power OFF the ISP modem, this device and RBR. then disconnect the RBR from the modem and directly wire connect this device to the ISP modem. Power ON the modem then power ON this device and check again.
- gjrandazzJun 21, 2021AspirantI meant VM. I have one through Google Cloud, where I use Parsec client on my Shield to connect to the VM (host). I have one satellite about 30 feet from router and the other around 60. It's a one floor home and it's pretty much open. There really isn't anything interfering with signal.
What I dont understand is my dl and ul speeds are around what they should be. I have no problems streaming 4K to other devices in my house. I'm on my phone right now and I get 600 mbps up and 35 mbps down. Could it be that my upload speeds aren't enough?- FURRYe38Jun 21, 2021Guru - Experienced User
Do you mean 600 down and 35 up?
If this one device is the only item that seems to be having problems, could be the devices as well.
Ensure your using a good quality LAN cable. CAT6 is recommended.
Would need to test directly to the ISP Modem with out the RBR and see if the problem still happens...
- gjrandazzJun 21, 2021AspirantYeah, 600 down, 35 to 50 up
I also get high latency on my computer, which is wired connected to the closer satellite.
I am using a Cat6 cable. Router and modem are very close to each other.
I'll try connecting my Shield to just the modem.
