Need-WIFI
Apr 24, 2022Follower
Best way to wire AXE11000 satellites, switchport or direct between devices?
Have the 3-unit package (RBKE963) with main WAP and 2 satellites. Have the option to connect the satellites directly to the ports on the back of the main WAP. Also have the option of pugging the ma...
CrimpOn
Apr 24, 2022Guru - Experienced User
Orbi routers expect the satellites to be connected through the router LAN ports. That's the way they are designed.
