litigator4lyfe
Mar 29, 2021Follower
BGW320-505 passthrough/RBR750 in router mode VS BGW320-505 Default/RBR750 in AP mode
Which is the recommended set up for the best performance? I am not a gamer. Just have a need for speed. I have the gig ATT fiber with BGW320-505. I purchased the RBK753 from Costco. What is bet...
Mar 29, 2021Guru - Experienced User
either would function about the same.
the difference would be in what features you want.
When in ap mode, certain features are disabled on the netgear.
Same with the att router, certain features get disabled in passthrough mode.
so its which features do you use/want for your setup. Netgear's features or att's.
seniorj
Jun 23, 2021Aspirant
Hello, I cannot seem to get either of the above devices to connect via my ATT modem/router. Tried the firewall settings, opening ports etc. Must be doing something wrong, any advice welocome. JS
- FURRYe38Jun 23, 2021Guru - Experienced User
What Orbi model system do you have?
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
seniorj wrote:Hello, I cannot seem to get either of the above devices to connect via my ATT modem/router. Tried the firewall settings, opening ports etc. Must be doing something wrong, any advice welocome. JS
