djunagi
Feb 04, 2022Aspirant
Bitdefender Armor never connects
I'm trying to get Bitdefender Armor on a MS Surface Studio laptop running updated win 11. When it trys to login and check the license, the connection always errors out. I have installed this on a f...
Patone407
Feb 05, 2022Tutor
Have a look at the DNS servers setting that your MS Surface is using compared to the other devices which connected successfully.
Typically it should use the router or your ISP as the DNS server but if your device/computer has a different one then that will be the one used to lookup the IP address of a website you are going to.
- djunagiFeb 07, 2022Aspirant
Patone407 I do have it normally running to the default dns servers provided by our AT&T modem . I also tried directing dns to 1.1.1.1. and 2.2.2.2.. No difference as it still could not connect.
- FURRYe38Feb 07, 2022Guru - Experienced User
What Orbi model is this?
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
