Fixxer808
Aug 28, 2022Follower
Blink sync module cannot connect with RBK763S
Is there a way to enable only the 2.4 ghz band so my Blink sync module can access my Orbi? I tried using the Netgear guest network, and it would not connect. When I log in to the router’s homepage, I ...
michaelkenward
Aug 29, 2022Guru - Experienced User
The Blink will only work on the 2.4ghz band. What’s the trick to getting this connected?
The Blink will not try to connect to the 5 GHz because it can't.
Why do you think you need to turn off the 5 GHz? You should still be able to set it up with a mobile device that is connected to 5 GHz.
It might be easier to force the mobile device to connect to 2.4 GHz rather than messing around with the router.
Fixxer808 wrote:
Is there a way to enable only the 2.4 ghz band so my Blink sync module can access my Orbi? I tried using the Netgear guest network, and it would not connect. When I log in to the router’s homepage, I don’t see any option to disable the 5 ghz band.
No. But you should not need to disable 5 GHz to get things to connect.
This is a constant complaint about crappy apps from IoT cowboys. who just don't understand how Mesh wifi works.
Try reading this:
Search - NETGEAR Communities – "Blink sync"
Orbi Mesh Wifi is not connecting to with Blink Syn... - NETGEAR Communities
