amvogel5's avatar
amvogel5
Follower
Jul 07, 2021
Block Guest Network Access
How do I block Guest network LAN access on the RBK852 Orbi Mesh System? With the RBK50 Obri system, the Main and Guest networks had the same base IP address 192.168.1.xxx but with the new RBK852 system the Guest network uses the 192.168.2.xxx base IP address and I can't setup any LAN's using the 192.168.2.xxx base address to limit or block internet access.
1 Reply
  • FURRYe38's avatar
    Guest Network is a separate network and is never on the same netowrk as the LAN side.
