KG_RBR750
Oct 04, 2022Aspirant
block wifi on schedule on RBR750
The schedule is not working; it did before, but I'm not sure if it was before firmware update to V4.6.9.11_2.3.5 I want wifi to be blocked from 11:15pm to 6am every day. I checked to be sure tim...
- Oct 04, 2022
Seems to be a new issue in FW:
We've made NG aware of it.
Oct 04, 2022Guru - Experienced User
KG_RBR750
Thank you - I guess I should roll back to previous firmware? How?
- FURRYe38Oct 04, 2022Guru - Experienced User
You can if previous FW version worked.
What version had you been using?
Same way as you manually update FW. Download the files to a PC and send to the RBS/RBR web page. RBS first then RBR lastly. Though you might leave the RBS were there at and just downgrade the RBR. RBS should continue to work after the RBR is downgraded.
- KG_RBR750Oct 04, 2022Aspirant
I don't know which firmware was the last; it upgrades automatically (or I check and allow). I'm going to guess 4.3???
Sorry, I don't understand RBS/RBR...
You might try v4.6.8.5.
I would avoid going any lower then that.
RBS = Satellite
RBR = Router
