LaurentCr
Jul 12, 2022Aspirant
Blocked time starting evening and ending morning does not work
I want to restrict my kids playing at night and have setup a blocking schedule (and IP address reservation). Now it's 6am. When I set the schedule from 21 hour to 7 hour, then the device can connect...
- Jul 12, 2022
LaurentCr wrote:
It seems the system cannot cope with blocked schedule start time higher than end time.
How to mitigate this ?
This is exactly what I discovered. Terms such as "brain dead", "dumber than dirt" come to mind. This is not a useful tool because (a) there is only one schedule, and (b) the start time must come before the stop time.
My impression is that Netgear has no incentive to alter this because they would rather customers subscribe (pay money) for the illusion of Parental Control.
I suggest you set it from 21:00 to 23:59 and hope that they go to sleep before midnight. "Who cares" if they get up early and start using the electronic device that you gave them? Or.... find a different solution.
LaurentCr
Jul 13, 2022Aspirant
Ok thanks. That's what I ended doing finally.
Jul 13, 2022Guru - Experienced User
Enjoy. 📡
