dgrandshaw's avatar
dgrandshaw
Blue solid light on Orbi satellite
Hi - So I have good connectivity on my two saltellites back to the router. The satellite has a solid blue light that is always on. I thought that the light went off after syncing with the router afte...
  • FURRYe38's avatar
    Sep 15, 2021
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
