dgrandshaw
Sep 15, 2021Aspirant
Blue solid light on Orbi satellite
Hi - So I have good connectivity on my two saltellites back to the router. The satellite has a solid blue light that is always on. I thought that the light went off after syncing with the router afte...
- Sep 15, 2021
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
dgrandshaw
Oct 04, 2021Aspirant
It is just a surge supressor power strip from trip-lite - nothing special. I plugged the satellite directly into the way and did the 30 second reset as suggested by support. Time will tell if it keeps resetting.
Oct 05, 2021Guru - Experienced User
After a period of time, if the RBS continues to work, plug it back into the power strip and test.
Possible you may have a bad power strip.
