TrayeP10
May 18, 2022Aspirant
Bose Activation Failed
I recently switched internet providers and also upgraded to the Orbi RBRE960. When I try to add my Bose products to the new Wi-Fi I am able to get the Bose product to connect to the Wi-Fi however on t...
May 18, 2022Guru - Experienced User
there should be a fibre gateway with a model number on it. Do you have that?
Also, are you using ios or android for setup?
TrayeP10
I’ll try to get that information.
Using iOS. I have tried it on 2 different phones.
- plemansMay 18, 2022Guru - Experienced User
Make sure that icloud relay and private mac/ip address is disabled on the ios device.
We've seen issues on the apps when users are using those features on ios.
