Meggo
Jan 06, 2025Aspirant
Both Orbi RBS750 Satellites disconnecting after a few hours
I have an RBR750 router in router mode in a mesh network with two RBS750 satellites all on FW version 7.2.6.31. It has been working fine on this version for a few months but in last week the satellit...
CrimpOn
Jan 06, 2025Guru - Experienced User
Message 1 does not indicate how the two satellites are connected to the router or how they interact with those two unmanaged switches.
- Satellites use the default WiFi backhaul connection. No connection to either of the switches.
- One or both satellites are connected to (one? both?) of the switches.
FURRYe38 is correct that the Community Forum has numerous negative comments from users about the ".31" firmware release and a common tactic has been to downgrade to ".21"
- MeggoJan 07, 2025Aspirant
Neither satellite is connected via ethernet or connected to the switches so are both using the default WiFi backhaul.
I haven't had time to try the downgrade yet but overnight rebooted the closest satellite and switched the other one off - and it seems to be working - ie first satellite is still connected to the router. The second satellite is around 20ft away from the first in line of sight across open plan living/kitchen area. It also has an Apple TV connected via ethernet that is used as the home hub.
