tunar
Nov 23, 2023Aspirant
Both Orbi satellites disconnecting from mesh simultaneously (RBR750 + RBS750)
Hi all, My satellites are disconnecting simultaneously and I'm not sure why or how to fix it. Network set up: I have an Orbi RBR750 router with 2 RBS750 satellites. Router is connected to IS...
Nov 23, 2023Guru - Experienced User
Try putting the ISP gateway back in router mode (disable its wifi) and then the orbi in access point mode.
See if that keeps it stable. I've seen ISP firmware pushes cause issues so its worth checking
- tunarDec 01, 2023AspirantThanks for the suggestion! I have now factory reset everything (ISP modem, Orbi router, and Orbi satellites) and I'm still having the same issue. Is it possible that there is a firmware issue?
- plemansDec 01, 2023Guru - Experienced User
Is the orbi in AP mode?
- tunarDec 03, 2023Aspirant
Router mode - unchanged from before this issue started.
I was away for the weekend. When I left, the satellites had disconnected themselves. At some point during the weekend they managed to reconnect. Very odd behaviour.
