tunar
Nov 23, 2023Aspirant
Both Orbi satellites disconnecting from mesh simultaneously (RBR750 + RBS750)
Hi all, My satellites are disconnecting simultaneously and I'm not sure why or how to fix it. Network set up: I have an Orbi RBR750 router with 2 RBS750 satellites. Router is connected to IS...
tunar
Dec 01, 2023Aspirant
Thanks for the suggestion! I have now factory reset everything (ISP modem, Orbi router, and Orbi satellites) and I'm still having the same issue. Is it possible that there is a firmware issue?
Dec 01, 2023Guru - Experienced User
Is the orbi in AP mode?
- tunarDec 03, 2023Aspirant
Router mode - unchanged from before this issue started.
I was away for the weekend. When I left, the satellites had disconnected themselves. At some point during the weekend they managed to reconnect. Very odd behaviour.
