RJP48
Aug 26, 2020Follower
Bought Orbi RBK750 mesh wifi 6 Sri band system--
Purchased system noted above. I currently have a Motorola modem/router. I want to: Disconect router in motorola unit. Conect to NEW ROUTER (not yet purchased). I have been surching for the Net...
Aug 26, 2020Guru - Experienced User
CM model modems are just modems only. Not mode/router combo units. It is recommended to get a CM modem to use with the RBR750 system as that is a router. All it needs is a modem. Any of the CM series modems will work. CM1000, 1100 or 1200. The CM is not released yet and not sure. It was mentioned it is due for releae soon however no dates were given. I would recommend a CM1100. I believe CC supports all of the mentioned CM series modems. .
