paulmHK
Jul 27, 2021Guide
Brand new Orbi RBR750- Very slow routing from devices to internet over Wifi
Hi all, Apologies for the overlong post but I am in need of some advice..... I recently brought a new Orbi RBR750 + 2 Satellites. My home setup uses a combination of wired internet access (e.g....
paulmHK
Jul 30, 2021Guide
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
ISP Modem - Its a Huawei modem from the telco (i will check the model# later)
Home Size - An apartment thats Approx 1000 sqft, all on one level
Distance betweem the Router and Sats : The router is in the living room, in an elevated position. The Sats are in adjoining rooms. I would Say Sat 1 is about 8 ft from the router (but separated physicaly by a wall) Sat 2 is probably around 20 - 254ft or so from the router, separated physically by 2 adjoining walls.
The backhaul status of each satellite is ''Good''. Both are connected to the Orbi Router with a connection type of 5G.
I have updated the firmware of all to V4.6.3.7_2.0.40
I've noted some of the other changes suggested on this thread but may hold off making any config changes and see the impact of the firmware update has. Will post a status in due course.
Jul 30, 2021Guru - Experienced User
Distance betweem the Router and Sats : The router is in the living room, in an elevated position. The Sats are in adjoining rooms. I would Say Sat 1 is about 8 ft from the router (but separated physicaly by a wall) Sat 2 is probably around 20 - 254ft or so from the router, separated physically by 2 adjoining walls. 8 and 20 feet maybe too close between the RBR and RBS. What materials are these walls?
