zielin
May 26, 2021Tutor
Brand new RBK753 losing connection
I just purchased the RBK 753 3 unit Orbi package from Costco and am having some connectivity issues with it so far. The issue that occurs most frequently is my Chromecast will lose connectivity. S...
May 31, 2021Guru - Experienced User
zielin wrote:Firmware downgrade didn't fix the issue either. I'm still experiencing disconnects.
Yes, I still have my old router.
Possible to set this up as your main host router and set the RBR for AP Mode? Would be interesting to see if RBR still sees problems. Be sure all other wifi radios on the spare router are fully disabled.
I did notice while I was performing the firmware update that the logs showed an entry saying the Internet had disconnected. Expected during an update, but I'm also wondering if it will log this event during these other disconnects I'm experiencing.
Wondering if there maybe a problem at the ISP modem level? Spectrum Cable Model Docsis 3.1 Model E31T2V1.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Problem is when I go to the logs interface it only displays the last ten entries. Is there a way to view the full logs? Ya been a known problem with log logs not showing more then several entries.
zielin
Jun 02, 2021Tutor
As of last night I've switched back to my old router. The connection is again stable. The stability issue began and ended with the Orbi router. I think this rules out the ISP as being the cause of the issue. Unless the Orbi is somehow just incompatible with the modem or ISP configuration.
Running the Orbi in Access Point mode is tempting. Just to satisfy my curiousity. I may give this a try if I can find some time. Though even if it worked I wouldn't want this as a long term solution. One of the goals in all of this was to get rid of my old out of support router.
I'm still waiting on Netgear support to get back to me to see what else they have up their sleave, but at this point I'm unfortunately leaning toward just returning the Orbi. I was willing to spend more than I normally would on a router because of the good reviews and promise of a solid connection everywhere without having to expend a bunch of effort. However, my experience so far has been the exact opposite. It's just not worth several hundred dollars for a router that is going to require a ton of effort to *maybe* eventually give me a stable connection.
- FURRYe38Jun 02, 2021Guru - Experienced User
If your in touch with NG support, see if they can get you an RMA for the RBR. Sounds like the RBR is faulty. If you can't get anywhere with NG support, I would be sure to return the system to place of purchase with in the return period.
Would be good to try AP mode on the RBR and see if the problem still happens or not.
zielin wrote:As of last night I've switched back to my old router. The connection is again stable. The stability issue began and ended with the Orbi router. I think this rules out the ISP as being the cause of the issue. Unless the Orbi is somehow just incompatible with the modem or ISP configuration.
