zielin
May 26, 2021Tutor
Brand new RBK753 losing connection
I just purchased the RBK 753 3 unit Orbi package from Costco and am having some connectivity issues with it so far. The issue that occurs most frequently is my Chromecast will lose connectivity. S...
titaniumrx8
Jun 02, 2021Apprentice
zielin
Since you bought from Costco, you also have option to buy a nice Nighthawk class router. Since your router can be centrally located and only have 1000 sq ft, unless you have a serious dead zone why go mesh?
My house is 3000 sq ft concrete construction, "U"shaped single floor and successfully used a Tri-band Nighthawk and a single Tri-band extender for 5 years. I went mesh to simplify management and to get wired ethernet ports into 2 locations to replace ethernet over power adapters for some equipment that have no wireless capabilities.
- zielinJun 02, 2021Tutor
Despite the small area and the existing router being centrally located, there are still a couple spots in my home that don't perform optimally over wifi. I suspect it is due to the tens of other wireless networks surrounding me. I was hoping a mesh solution might help with this and provide me solid coverage everywhere. I wasn't aware at the time that Orbi also has a recommended minimum distance between units.
The ability to have a wired connection to the sattelite was also a bonus. I also had a similar configuration using a pair of tp-link ethernet over power adapters at one point.
I saw Costco had a nighthawk branded mesh router available at the same time I bought the Orbi. It was actually significantly cheaper. I decided to pay for the Orbi in hopes of avoiding just the kinds of problems I'm now seeing.
It sounds like you're talking about one of the stand-alone nighthawk units though (not mesh), right?
- titaniumrx8Jun 02, 2021ApprenticeYes, one of the standalone routers. My 5 year old r7900 Nighthawk was located at the far end of my house and still provided fair signal at 5g and strong signal at 2.4g 80' from the router through multiple walls. The extender was mostly for getting signal turned 90° to support devices down the wings of the house.
My current Orbi 753 also bought from Costco places satellites in a fairly straight line with the router. The router still at the far end of the house because that's the only practical place for the modem and router without significant re-wiring. Satellite 1 is about 25' from the router through 3 interior walls and satellite 2 is about 60' from the router through 4 interior walls. Both show good strength on the backhaul and both make direct runs to the router according to the network map. I think they're both direct to the router because I turned the father one on before the closer one. Haven't bothered to try to force them to daisy chain since everything is working.
