Surfer10k's avatar
Surfer10k
Bridge mode and AXmode
Hi everyone, I have the Orbi RBR850 set (2 satellites) My problem is the that my IP standard modem/router uses 192.168.178.x as its ip address base. The Orbi uses 192.168.1.x I have switched wifi...
  • Surfer10k's avatar
    Mar 28, 2024
    I decided that getting into DMZ etc was a little above my paygrade 😁
    I set the obi to AP mode. This solved my problem. The Orbi is still accssible via the app. and all of my devices are now on one network.
    Thanks for the help.
