kahoo614's avatar
kahoo614
Follower
Apr 12, 2024
Broadband upgrade question
Hello, currently, I have a 1000 Mbps broadband connection at home, and I'm planning to upgrade it to 2000 Mbps next month. I'm using the RBK752 Mesh WiFi system. Will it be able to support the 2000 Mbps broadband?
If not, is it possible to upgrade only the main router and repurpose the existing RBR750 router and RBS750 satellites as satellites?
Hello, if you currently have a 1000 Mbps broadband connection at home and plan to upgrade it to 2000 Mbps next month, you are using the RBK752 Mesh WiFi system. You would like to know if it can handle the 2000 Mbps broadband.
If it is not capable, you would like to know if it's possible to upgrade only the main router and convert the existing RBR750 router and RBS750 satellites into satellites.
