titaniumrx8
May 31, 2021Apprentice
Bryant Connex thermostat won't connect to Orbi RBS753
The Bryant Connex thermostat is the same as Carrier Infinity and only works at 2.4ghz. Had no issues connecting to the Netgear Nighthawk which I replaced with the Orbi. Suggestion on this forum t...
- Jun 01, 2021
Turn OFF all RBS to help elimiate seeing to many SSID names.
Disable AX mode on the RBR:
Set CTS values to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings. Save settings and apply.
If the Controller is taking 20 minutes to report back that it can't connect, this would not be a Orbi problem. Contact the Mfr about this. Shouldn't take that long. My NEST report with in seconds if it can't connect for some reason.
titaniumrx8
Jun 02, 2021Apprentice
Can this thread get merged with the same thread on the Orbi AX board?
- FURRYe38Jun 02, 2021Guru - Experienced User
I've asked to have this tread moved to the AX forum since your system is the AX model...Can't be merged with other threads though.
