titaniumrx8
May 31, 2021Apprentice
Bryant Connex thermostat won't connect to Rbk753s
The Bryant Connex thermostat is the same as Carrier Infinity and only works at 2.4ghz. Had no issues connecting to the Netgear Nighthawk which I replaced with the Orbi. Suggestion on this forum t...
May 31, 2021Guru - Experienced User
Try disabling AX mode on 2.4Ghz:
