titaniumrx8
May 31, 2021Apprentice
Bryant Connex thermostat won't connect to Rbk753s
The Bryant Connex thermostat is the same as Carrier Infinity and only works at 2.4ghz. Had no issues connecting to the Netgear Nighthawk which I replaced with the Orbi. Suggestion on this forum t...
May 31, 2021Guru - Experienced User
Try disabling AX mode on 2.4Ghz:
titaniumrx8
Jun 09, 2021Apprentice
It appears that I was setting up the Orbi during a week when the Bryant servers were crashing frequently. Things stabilized a few days ago.
Now I can try reverting some of the settings to see if I can get better performance. On my old Nighthawk, the read/write across the network to my NAS (wired or wireless) was consistently 100+MBs, with the Orbi, it's only 40Mbs.
