timtom27
Jun 15, 2021Aspirant
Buffalo NAS shows 3 blank vulnerabilities on RBR750
I have an RBR750 (AX4200) mesh router with 2 satellites. I've plugged in my Buffalo NAS LinkStation and it works fine, but I'm confused by the Security Vulnerabilities then shown in the Phone app. I...
Jun 16, 2021Guru - Experienced User
What iPhone app are you referring too?
timtom27
Jun 16, 2021Aspirant
The one that looks like this
- FURRYe38Jun 16, 2021Guru - Experienced User
Use the Choose File button on your port to attach a picture capture to your post. Inline pictures have to be approved and we can't see them until then.
Is this ther Orbi app?
- timtom27Jun 16, 2021Aspirant
I did use the Choose File button to attach the pic.
But yes, the app is the Orbi Netgear app I'm talking about
I open it, select the "Security" icon, and it shows a section saying "Vulnerabilities Detected" with the number 3. I select that and it shows
"Buffalo NAS LinkStation (3). It shows 3 blank lines below it. I touch that icon and it shows "Loading Data..." but then comes back with nothing changed.
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
