TheCube
Mar 28, 2023Aspirant
[BUG] IPv6: 6rd support breaks after an IPv4 change
Hello, For context, I'm using CenturyLink fiber, which offers IPv6 through 6rd. The problem: with 6rd, IPv6 autoconfig works only on the initial connection. It does not happen on subs...
Mar 29, 2023Guru - Experienced User
You could trying centurylink's gateway and connecting the orbi in AP mode.
- TheCubeMar 29, 2023Aspirant
plemans wrote:You could trying centurylink's gateway and connecting the orbi in AP mode.
Yeah, I know how to work around it, but a bug is still a bug 🙂 I'd rather reboot weekly in this case.
Also the combination of Orbi in AP mode + CenturyLink router is not something I like. Orbi in AP mode requires the upstream router to respond to ICMP pings otherwise it will reboot endlessly. And interestingly, on the CenturyLink router, there is no way to enable LAN-side ping without also enabling WAN-side ping (it's all under the "stealth mode" option - it's all or nothing). And I don't really like having my router responding to pings from the internet.
