TheCube
Mar 29, 2023Aspirant
[BUG] IPv6: 6rd support breaks after an IPv4 change
Hello, For context, I'm using CenturyLink fiber, which offers IPv6 through 6rd. The problem: with 6rd, IPv6 autoconfig works only on the initial connection. It does not happen on subs...
TheCube
Jul 21, 2023Aspirant
I'm currently on beta firmware version 7.2.6.21 which they sent me yesterday. I've tested a bunch of beta versions in the 7.2 series in the past 4 months.
(I have signed an NDA for the beta firmware, but the NDA doesn't prevent me to disclose the above - I'm only prevented from sharing the files)
Jul 21, 2023Guru - Experienced User
Are you in the beta project or did you submit the request thru the surveymonkey link?
