TheCube
Mar 28, 2023Aspirant
[BUG] IPv6: 6rd support breaks after an IPv4 change
Hello, For context, I'm using CenturyLink fiber, which offers IPv6 through 6rd. The problem: with 6rd, IPv6 autoconfig works only on the initial connection. It does not happen on subs...
Jun 01, 2024Guru - Experienced User
What beta FW version did you get that seem to fix what you were seeing?
Have you tried a custom IPv6 DNS address vs decteded ISP IPv6 DNS?
TheCube
Jun 01, 2024Aspirant
Hey - I replied to your DM where you asked some of these questions.
Note that the bug has been independently reproduced by BugCrowd through the Netgear bug bounty program. They used their own hardware to reproduce (probably in a black box environment - no ISP, no ONT). This is purely a firmware issue - IPv4 address changes aren't properly handled by the IPv6 stack. The Netgear support case (and Bugcrowd submission) has all the details
- FURRYe38Jun 01, 2024Guru - Experienced User
OK sounds good.
Will get this to NG and see if we can get some more traction on it.
Ya the fix in the beta they gave you didn't get into following released versions. Wondering why. 🙄
See what we can do.
