webminster
Jul 17, 2022Luminary
Bug? Missing clients on attached devices list
Have an RBK752 system, now on v4.6.8.5 (has happened on previous versions as well). I usually do not see a full accounting of all the devices on my network. I often do not find devices I know are c...
webminster
Jul 18, 2022Luminary
AP Mode, No parental controls or anything other than basic AP services.
For instance, I'll see a Ring doorbell on a satellite, and no entry on the router attached list. Lots of entries on the Satellites attach list are missing IPs. I see "Wired" connections listed on the router, but not all of them that are up and running.
To me, basically the connection accounting and reporting is way broken, missing entries (not a good security posture), less reliable than past firmware releases (which had problems too, just not as bad).
-Alan
ekhalil
Jul 19, 2022Master
webminster wrote:AP Mode, No parental controls or anything other than basic AP services.
The responsibility for creating and maintaining the ARP table is on the router (which is not Orbi in your case when Orbi is in AP Mode). The device list that you see in now Orbi (in AP Mode) is just for information and Orbi does that by doing ARP broadcasts and updates, and then gets a "best-effort" ARP table (attached devide list) that is -usually- not comprehensive.
Only in Router Mode, Orbi will do a full and relaible attached device list.
- webminsterJul 20, 2022Luminary
That's pretty stunning. Other APs I've used can actually keep track of what clients are connected. Cannot believe that would be considered proper behavior.
