beansontoast
Feb 26, 2023Aspirant
BUG: Orbi no longer using port forwarding after restarting - but settings still listed correctly
Hello! As in description, this is reproducible for me 100% of the time when doing the following: - set up an entry in port forwarding - check it works (it does!) - power down your Orbi router* ...
beansontoast
Feb 28, 2023Aspirant
What Orbi model is this in reference too?
This is happening on the RBR350.
It's connected straight to the OpenReach box. I don't have any other internet or connectivity issues.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Yes - I am.
Be sure your actively using the port or trying to use the port configuration.
Yes - I am. As in my original post, the port forwarding works fine until the router is reset - at which point, it no longer works until I re-add it in the configuration. (despite it still being listed).
Be sure uPnP is disabled on the RBR before setting up any PF configurations.
uPnP is disabled.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System?
I have tried these things as you have suggested, but the bug still persists. It is 100% reproducible. It seems to me this must be a bug in the firmware that it does not properly re-initialise port forwarding when the router boots up, only when new configurations are added.
