spe203
May 22, 2022Aspirant
c3700 modem compatibility with orbi rbk852
Can someone enlighten me about my old modem(c3700) connecting to a mesh network(rbk852) will it be compatible? Thank You
michaelkenward
May 23, 2022Guru - Experienced User
Thank You
No reason why it shouldn't work.
The best way to make them play nicely together would be to disable the modem bit of the c3700 modem/router.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual
Cable Your Modem Router to a Router or Gateway
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
