spe203
May 22, 2022Aspirant
c3700 modem compatibility with orbi rbk852
Can someone enlighten me about my old modem(c3700) connecting to a mesh network(rbk852) will it be compatible? Thank You
May 23, 2022Guru - Experienced User
Will it work? Yes.
You can either run the C3700 in modem only mode or leave it in router mode. If you leave it in router mode just make sure the ssid is on a different channel/ the orbi is in access point mode (prevent a double nat), and the ssid is a different name than the primary.
(if it was me, I'd just use the c3700 in modem only mode).
I will say, the modem for the c3700 is a pretty base model docsis 3.0 device and isn't going to do much for speeds. If your speeds are greater than 100mbps, I'd be looking at upgrading it.
spe203
May 23, 2022Aspirant
Hi Sir,
I really appreciate for your brief response. Sorry Im not into tech, so I Have a follow up question for you
How do I set up my c3700 for a router or a modem only?
What we have is a 200 -300 mbps. If I connect my net gear orbi. will it give us those speed for wifi, or do I need to really change the modem, if so, what modem could you recommend.
Thank You so much
Sean
- FURRYe38May 23, 2022Guru - Experienced User
- michaelkenwardMay 23, 2022Guru - Experienced User
I did explain how discover how to go about that in my earlier message.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.C3700 | Product | Support | NETGEAR
Check the section in the manualCable Your Modem Router to a Router or Gateway
It is on page 12.
What we have is a 200 -300 mbps. If I connect my net gear orbi. will it give us those speed for wifi,You will never get wifi at that speed on many wifi clients, regardless of the modem you use. Wifi clients that connect at 2.4 GHz can't go that fast. Even some 5 GHz devices will have a hard time getting those speeds.
The speed you get is down to the wifi client as much as the source.
- spe203May 23, 2022Aspirant
Thank You so much guys
