czl6lx
May 17, 2022Aspirant
Can’t connect GE washer and dryer to new Orbi RBRE960
Had GE washer and dryer hooked up to previous Nighthawk router without any issues, switched to a new Orbi RBRE960 and now they will not connect. I also have the same issue with a Lennox iComfort the...
czl6lx
May 18, 2022Aspirant
Thank you for reply.
The router automatically created a new SSID, it appended the original with a -IOT, password is the same. All my other IOT devices connected flawlessly, but not the washer/dryer or my Lennox thermostat. My security setting for the -IOT is WPA2-PSK (AES), the only other option for this SSID is WPA-PSK (TKIP) + WPA2-PSK (AES).
Mikey94025
May 18, 2022Hero
Try setting your CTS/RTS Threshold to 2347 to maximize compatibility with older wireless devices:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to the Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
- czl6lxMay 21, 2022Aspirant
All good now! Most of my IoT devices connected to the SSIS that was appended with IoT at the end of the SSID, except for my washer/dryer and thermostat. Deleted the -IoT at the end of the SSID and all was good. Thank you for replies and help.
