czl6lx
May 17, 2022Aspirant
Can’t connect GE washer and dryer to new Orbi RBRE960
Had GE washer and dryer hooked up to previous Nighthawk router without any issues, switched to a new Orbi RBRE960 and now they will not connect. I also have the same issue with a Lennox iComfort the...
Mikey94025
May 18, 2022Hero
Try setting your CTS/RTS Threshold to 2347 to maximize compatibility with older wireless devices:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to the Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
czl6lx
May 21, 2022Aspirant
All good now! Most of my IoT devices connected to the SSIS that was appended with IoT at the end of the SSID, except for my washer/dryer and thermostat. Deleted the -IoT at the end of the SSID and all was good. Thank you for replies and help.
